Broadband Very Spotty - EE Smart Hub
srose8
We moved to EE around September 2022 and to begin with service was great no real issues however more recently there are so many connection issues for both wired and wireless devices.
Phones wireless connection speeds become seemingly at random super slow. Apps on a smart TV drop connection to services or the services run poorly - doesn't make any difference what service.
Is there anything that can be done to tweak the router settings or a firmware update that could be manually applied to rule out the router directly?
