Current broadband speed problem
FGTQ
Current bb speed has dropped to 8 mbs. Any known issues?
Mustrum
@FGTQ  you would be better having a look through the quick things to check on the Help pages, then let us know what you find.  My broadband is fine, but then again I have no clue where you are or if there is a localised problem where you are..
Quick things to check if you have a phone line, is it OK is there any noisec-cdial 17070 option 2?
Log into the router, are the sync speeds normal?
https://ee.co.uk/help/help-new/broadband-and-landline/home-broadband/how-can-i-fix-my-home-broadband...
