My broadband is flashing orange light
Wintana
My broadband is flashing orange light for almost 6 hours. I try to refresh it. It’s not coming. I tried to switch it off and on but it’s not working please I need help.
It sounds like you have no BB signal. was it working before?
If it is a neighbourhood issue, you could consult Check service in your area  to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
