19-09-2026 07:31 PM
Every 10-15 minutes the WiFi just loses connection and start flashing orange we have had this problem before with the power lead not giving out enough power too the router but we got sent a new lead but the same issue keep happening any idea on how to fix this?
19-09-2026 07:45 PM - edited 19-09-2026 07:54 PM
@Gppp It's always possible that it could be the power unit again as was very typical 15mins after reset it through it arms up and gave in, your only choice currently is to raise it with EE CS and see if they can send another replacement to you to try, when you say it keeps happening was it good after you changed the PSU out a while back?
