WiFi Extender 7 Plus - disable lights
jonathanbuller
We have an Extender 7 Plus in each bedroom of our house. I have the light turned off in the settings on the app, but when the hub loses internet or reboots (seems to do this most days around 3am) they'll all start flashing orange, lighting the room up and waking us all up 🤣 I've resorted to electrical tape but was wondering if there was a way to make them not have the light on at all, maybe only at night?
Ewan15
Expert Contributor
Expert Contributor
@jonathanbuller You can disable the lights on both the Router and the Extenders as you have discovered. However by design they will come back on if the device reboots or is restarted, so you know what is happening. Once the device has fully restarted and reconnected the lights go out and stay that way.
Hope this helps
bobpullen
@jonathanbuller - I'd be more worried that the hub is restarting/you're losing Internet almost daily. How long has that been going on for?
