09-06-2026 01:08 PM - edited 09-06-2026 01:12 PM
Just had this text from EE:
"Hi, it's EE.
27-06-2026 07:57 AM - edited 27-06-2026 08:01 AM
@JonT69 Think from your other post back you are on an FTTC copper connection and with the EE Smart Hub 6+ SH31B model. You need to go check again were it is at with the new FW versions and see that all off your settings are still current on the Hub. The connection could have just went out OR/EE side that will be indicated by the led state.
FW: r3.8.30-R-1627300-PROD-83002 and the gui is at App version 3.1.18 05/12/2025
FW: r4.26.1-R-1860948-PROD-83002 and the gui is at App version 3.14.5 25/05/2026 OP Posted Stability Problem
FW: r4.26.3-R-1923144-PROD-83002 and the gui is at App version 3.14.5 12/06/2026 OP Posted
The two pinned links in case you require are below.
EE Hub firmware versions - The EE Community
Fix problems connecting devices to your Smart Hub Plus or Smart Hub 3's WiFi - The EE Community
27-06-2026 08:04 AM - edited 27-06-2026 08:06 AM
@JonT69You have posted in something that is not relevant and not a Pro 7 Hub for you, answered in your other posting!
on 27-06-2026 01:44 PM
Thank you Jim and apologies.
on 27-06-2026 01:52 PM
@JonT69 No need for the apologies, looks like you are still pulling the hair out with it all though!
on 27-06-2026 08:27 PM
Thanks Jim and for all your excellent contributions.
Checked the firmware and I appear to have had the latest update so gave everything another reboot today and it’s all online and working.
Fingers crossed it stays that way!
on 27-06-2026 08:41 PM
@JonT69 All you can do now is keep an eye on it all, take the step back if anything untoward appears out off the blue with it!
New FW is such a pain at times especially when you had a working system that did behave itself before hand!
