EE acknowledge Wi-Fi connections issues
Cliff_G
Skilled Contributor
Skilled Contributor
Just had this text from EE:
"Hi, it's EE.
We're aware that some customers may be experiencing issues with devices connecting to Wi-Fi. If your Wi-Fi doorbell, camera, smart speaker or other connected device isn't working as expected, please try restarting your hub and the affected device to temporarily restore connectivity.
Our engineers are working to resolve this as quickly as possible. A temporary workaround is available now, and you'll find simple step-by-step instructions at https://ee.co.uk/sh3wifi  There's no need to call us, as the latest guidance is available online.
We're sorry for any inconvenience caused by this issue and thanks for your patience while we fix it."
That link eventually takes you to the same fix discussed here since last week, reset the 2.4GHz to fixed channel.
I'm very much hoping their fix will be a firmware update since the last update is what caused this. If you want to track whether this is what happens, go into your Router ( https://192.168.1.254 ) and note your current version. The one with the problem is r4.26.1-R-1860948-PROD-83002   so I shall be watching that, and hoping that it also fixes my 6-second reconnection problem on one device.
I've no idea whether another firmware update will reset any configuration you have applied (such as starting the compatible wifi, guest wifi, port forwarding, whatever) so it may also be worth noting down the changes you are running with.
65 REPLIES 65
Northerner
Hi @Cliff_G
If EE have admitted fault then surely some compensation will follow?
As I always say forget the free routers and buy your own as it will serve you better.
Maestro
Maestro
@Cliff_G Thanks for posting it up, there is the problem off bad FW oops, or just plumb out bad wifi signal, using the has happened over the last two weeks as the prompt to find out, anything before both fix the channel and do the comp covers both bases, only the EE Smart Hub 7 Pro and the EE Smart Hub 6 Plus are the two that have had new FW....
Cliff_G
Skilled Contributor
Skilled Contributor
I kind of doubt it, do we have a specified Service Level Agreement? That's usually only on a business connection and then only on a big contract.
Re. getting your own router, whilst I've done that in the past, it will mean you're totally on your own if things don't work, such as the incoming broadband signal.  EE can interrogate their own router in full, but will just slope shoulders if they don't get the right response due to you having your own router.  That may be ok for you or anyone sufficiently tech savvy, but having been in software support myself, I would not be making that recommendation to the average user without telling them what they may be in for in the event of problems.
As an example, I used a Cisco router years ago in my business as it would hold onto an old 2 Mbps ADSL signal much better and I used its capabilities to find out it was dropping the line every 30 minutes and 5 seconds.  I and Openreach eventually found was some timed pump starts in a quarry past which the copper cables went, and a small break was picking up RF interference. No, Plusnet's router couldn't have done that, but I had to learn Cisco's config language. I was definitely on my own, fortunately in the end it was Openreach's bailiwick so I didn't need to cough.
JonT69
This has caused me no end of trouble with my Amazon Blink security cameras, Octopus Smart meter, Bosche dishwasher and Vaillant Heat pump.
Have spent hours and hours reconnecting, rebooting and on the phone to the companies trying to fix the issues only to find that it is an EE issue.
Having messaged EE Support they effectively ignored the Firmware issue and made me go through the re-boot reset of the router.
24 hours later same problem and it’s kicking stuff off again so hasn’t been fixed yet.
Its simply not good enough and not the level of service we pay for and should expect.
@JonT69 Has the temporary fix helped to keep you up and running with the devices you mention?
JonT69
No it hasn't. Both the Valliant Heat Pump and Amazon Blink security cameras had all been kicked off my home network again.
@JonT69 Are you waiting to see if the two others also go off? Are you still on the old copper FTTC as per your post a year ago now?
JonT69
No the Valiant and Blink Cameras are the main offenders. Yes we're on FTTC albeit we have been advised that we should get fibre to the house later this year.
Please rest assured we have spent hours and hours trying everything to stop these ievices being kicked off including a dedicated comp  2.4ghz network etc .... however it is clearly the problem EE advised us of as it has been going on for weeks and nothing seems to solve it. Before the firmware update we had no issues whatsoever.
Hi, it's EE.
JonT69
The dishwasher and Smart Meter are more tolerant of the issue so whilst they will go off at some point in the next few days, they are not as volatile as the heat pump and security cameras
