EE Smart Wifi Pro
SeanyW
two questions on EE Smart Wifi Pro
how do i setup the extender with a permanent ethernet backhaul
I can pair via ethernet and have a solid aqua light but no wifi  available after pairing.  Is ethernet backhaul an option?
second question, is their an option to switch off status light on wifi smart pro completely and if so how?
Maestro
Maestro
@SeanyW To have a wired Ethernet cable backhaul, just connect the router to the smart wireless and it will set it's self up for wired backhaul, to turn off and/or control the LED lights for either the Router/Smart wireless, you can do by web manager and also possible with the app. http://192.168.1.254 web manger if you wish to do it that way. Help also explains what and how the led operates.
