EE Hub and TPLink Wireless Access Point
taylorhawkins
Hello there! Obligatory "sorry if this is posted somewhere else but I've searched and searched...".
So, recently moved into a property with an external annexe. The annexe has a network point connecting underground to the main house. In the main house, we've just got EE broadband (Fibre 67), with an EE Hub (SmartHub SH30A). The previous owners extended into the annexe with a TP Link Wireless Access Point (TL-WA801N), so I got one. I've connected the EE Hub to the network point, and I've connected the AP in the annexe also. I've got through the default Access Point setup.
I've tried it with no settings changes and the TP link user/pwrd. I've tried changing the user/pwrd to the EE hub one. I've changed the AP to StaticIP and disabled DHCP. Each time I get a wifi connection available that I can connect to, but can't load any webpages etc. (using an iPhone, but I don't get a "No internet" note on the connection either).
I'm ok with computers, but it comes to network stuff my limit is mostly reached beyond simpler stuff.
What am I missing? Please help 😄
That page only gave the option to enabled or disable WiFi (it was enabled) and to update channels etc. as well as the login details
However, after five hours of back and forth today, for whatever reason, the WiFi suddenly started working. So… WAHEY!
Thank you for your replies!
8 REPLIES 8
Community Hero
Community Hero
@taylorhawkins The tp-link setup videos below.
Edit:- Reset the OLD Tp-Link back to it's default settings, setup the TP-Link Admin/Password so you can admin the device, then setup the Tp-Link AP mode as required, it's default settings in that mode should work if it does have a WPS mode button do it for both devices and will take a look at it's manual if you post back that you are not able to get it to work. Is a pretty old AP device point, do allow 30 seconds for the EE Router nic to see the device on the cable port!
You would also find that the TL-WA1801 is closer in spec to the EE hub, but you will get the slower link speed on the older version that you have!
Download for TL-WA801N | TP-Link United Kingdom
What is the "the TP link user/pwd"? The TP-Link shouldn't need any username/pwd; the PPPoE auth is solely done by the EE SH+ (SH30A).  You should be setting the WAN of the TP-Link as Ethernet not PPPoE.
Thank you for this. But unless I’m being a moron, I cannot see an option to do this in the TP Link settings/admin page.
I have confirmed the Ethernet port works. So I’m very confused!
Show us the WAN settings page. Isn't the 1 where you are trying "the TP link user/pwd"?
@taylorhawkins See the link and the Q1 for how to reset!
7106511227_TL-WA801N(EU)_QIG_V1.pdf
Thanks Jim. I had that instruction page in the packaging, but alas, it didn't seem to solve anything as I followed all the instructions.
But, and I've set it as the solution comment now, but everything suddenly just started working. After a fair few hours, admittedly on and off, I got there in the end, and I'm relieved enough that I'll ask questions another time haha.
@taylorhawkins Good you got it all going and passing data, just remember that it has only a fast Ethernet port on it so 100Mb/s is as fast as it goes down the cable pipe to the EE Router. And that is fast enough for most system to operate on!
