Difference between Smart Hub Plus SH30A and SH31B (FTTC)
drmeister
Valued Contributor
Valued Contributor
This morning I received a new Smart Hub Plus from EE. I was expecting SH31B model but received instead a SH30A hub. Is there any differences between the two?
Thank you
36 REPLIES 36
@drmeister Looks like just early release with regards to the SH30A, comp / guest but it may be more flexible not much info about it, so you are the one up front and centre, doing a grand job so far.
Mustrum
@drmeister  just approved your latest pic.
However rejected an earlier one that showed your SSID and both Admin and WiFi passwords. I notice you have another with the same info, but not sure if it has been approved, but would recommend you delete that.
drmeister
Valued Contributor
Valued Contributor
how do you do deletes?
@drmeister Down arrow in the box you have posted, you should see delete that part of the post, but there are possible time constraints.
drmeister
Valued Contributor
Valued Contributor
done it thank you!
Mustrum
I have done it for you, although my way leaves a funny symbol on your post, which you may be able to delete using Jims method.
But yes there are time constraints.
Profile closed
Not applicable
So theres:
  • SH31B
  • SH32B (No DSL Port version)
  • SH30A (Different firmware/GUI versions, possibility different chipset? Similar to what we had with the BT Home Hub 5 Type A and Type B)
@Profile closed 30A does seem to be AX compatible so cannot see the reference to the older BT Routers.
Mustrum
@JimM11  Once upon a time BT introduced two versions of the BT Home Hub 5, both had similar specs, but used different DSL chipsets, the B version for cabinets that were not the same as those matched to the A version. I could look it up again, but .......
Wi-Fi I don't believe there's much difference. The 30A has a GbE WAN port though, whereas the 31B is 2.5GbE.
