Factory reset does not work
strongLioness
EE TV Pro box, has been working fine, now it is not, I have tried all the suggestions on EE TV website, even the factory reset, but the best I get is the EE logo, then nothing just a black screen. The aqua light is on, I have used different HDMI ports and different cables made no difference.
Anything else I could try? or has the box defunct?
Profile closed
Not applicable
Are there no menus , no graphics at all just a black screen across the board ? , i ask as you did the factory reset ? , thats usually done from within a settings menu , or did you do this using the physical buttons method ?
No menus, initially when it restarts the EE logo comes up for a few minutes then straight back to black screen. No graphics or anything else.
i used the physical buttons method.
Profile closed
Not applicable
That is strange you are connecting it directly to the Tv yes , no HDMI switches Etc ? if so it might be an idea to call CS as possibly there is a fault on the boxes software Etc , being it was fine before on the same Tv this is possible., i take it it is all the exact same setup ? , just the Box suddenly started presenting a black screen ? , nothing  in the setup as been added or removed ? , if thats the case then the Box may have malfunctioned , might be an ide to call CS , it was working before so for it to suddenly stop working could be a fault
Yes nothing has changed, connected direct to the TV and no other changes made, just stopped working and gives us a black screen.
Thanks I will get in touch with CS tomorrow.
Profile closed
Not applicable
Hopefully they will either send you out a new box or get to the bottom of the issue.
