Connections to base unit not close to hub.
Malthouse
Does anyone know how i can iperate my landline without plugging it into hub. My incoming line is where my base unit and answerphone is. My hub is on another hard wired point. Any ideas?
You should have been sent a DECT adapter that can be plugged in anywhere, into which you can plug your DECT base station. If not, ask for 1.
Malthouse
I have is a ADSL filter. If i plug my base unit into the other had wired outlet which is the incomming line it will not work. It has to be plugged into the hub.
The adapter is not a DSL filter. It is a box with a normal phone socket that plugs into the mains & links with the router by WiFi.
You can see 1 in this video (BT equiv): https://youtu.be/6f9UIOOlv_E
