Getting "Too Close" warning on Smart Wifi Plus
worthywow1
I have just switched from BT to EE. I have a Smart Hub 2 (SH31B) with three Smart Wifi Plus extenders which all have hard wired connections.
All seems to be working ok apart from occasionally losing connection for a minute - I'm still investigating this.
When looking at the app I'm getting the below warning saying the device is too close. It's not too close 🙂 It's about 30 metres away through floors and walls! It's further than the living room which is showing as ok.
Does anyone know what causes this message?
14 REPLIES 14
Mustrum
@worthywow1   have you tried moving it further away? It may well be that the signal in that location from the base and other extender already gives a strong enough signal.
Maybe even just putting it behind an object or cupboard may help - but the key is to try moving it or even doing without it.
Thanks - it is at least 10 metres from the nearest extender through a floor and a couple of brick walls - it's also behind a monitor and hardwired so presume defaults to not using the wifi to form the mesh? If I turn it off then I get no wifi signal in the room so the warning message is probably a bug, false alarm etc.
I have decided to revert back to my original BT hub and extender discs - with the new EE hub I am getting occasional drop outs and also my work laptop VPN doesn't like it!
Ewan15
Expert Contributor
Expert Contributor
@worthywow1  I get the same message from the EE App about my Extender. I ignore it and everything is working fine.
The extender connects to the devices closest to it.
Not experiencing any speed issues or dropouts.
bobpullen
@worthywow1 - I think the proximity warning is based on some arbitrary decisioning that says - 'if wired backhaul, then too close'. It's confusing/misleading but I don't think it's anything to worry about.
Source: I've always seen the same with my wired extender and it's positioned optimally.
JayCee999
I have the same warning but on a WiFi / mesh connected device. Its several metres and walls away, so not sure why its showing. It seems to work fine.
Leanne_T
Hi there @JayCee999
Could you try restarting the router and logging in and out of the app, does the message still show?
Leanne 🙂
Can this be done? My new hub and extenders have been nothing but trouble. Haven’t yet sent back my old bt hub and discs.
Rach_H
Hi @Su76,
Welcome to the Community!
It's definitely worth reaching out to our team to see what we can do to improve the service you're getting.
Rach
Hi Su76,
For me (on EE full fibre) using the old BT hub and extenders have been working rock solidly (if such a word!) without any issues so give it a go!
