Getting "Too Close" warning on Smart Wifi Plus
worthywow1
I have just switched from BT to EE. I have a Smart Hub 2 (SH31B) with three Smart Wifi Plus extenders which all have hard wired connections.
All seems to be working ok apart from occasionally losing connection for a minute - I'm still investigating this.
When looking at the app I'm getting the below warning saying the device is too close. It's not too close 🙂 It's about 30 metres away through floors and walls! It's further than the living room which is showing as ok.
Does anyone know what causes this message?
14 REPLIES 14
Kielty1
agreed, the app shows 'too close' when connected via ethernet no matter how far away. I have 2 extenders, 1 wifi all good, the other wired and in a different building! shows 'too close'
Someone really needs to update the app.
I wish I was not so eager to send back my BT hardware. Connection issues, especially with Sky Q box, are a daily occurance now, where with the BT equipment, I never had one drop-out. I think I need to get back to EE, because they are not providing a service. I also note that the EE hybrid connect only uses 4G, whereas the BT equipment it replaced was 5G.
@kernowman If you had the Hybrid connect from either BT or EE version, then they have only ever been 4g.
I have always found the sky box and q box advice network to be rubbish/unstable. My personal view , based upon nothing but experience in my own home is that the sky box is not really very good on a WiFi network. Prior to having full fibre I had a router in the middle of the house hardwired to  the tv and sky box by Ethernet cables. When I changed to full fibre I could no longer use the Ethernet network because the fibre connection was placed at the front of the house and the Ethernet wall ports were in the middle. Placing a Disc in the lounge near the tv and sky box did not produce very good results regarding the sky box. Eventually I used a short Ethernet cable from the EE disc to the skybox. The difference in performance was remarkable. Checking the sky box settings indicated an Ethernet connection rather than WiFi. I now have a EE pro hub and pro extenders. These have dual Ethernet ports on the back so I am now using the house Ethernet network again. When it comes to a sky box I would always recommend trying a Ethernet connection - even if it’s just to a Disc.
@MS1961 Best way to do it, the sky Q mesh / mini's really requires a good wireless wifi back to the main sky Q box, Ethernet get's rid off that!
