13-01-2024 11:48 AM
Having real issues connecting a Google Nest Mini and a Sonos Play 1 to the Hub. I can set up a Chromecast Ultra fine, which makes it all the more perplexing. I've tried at the usual stuff people recommend and even switched to WiFi 6 compatibility and WiFi 5 mode, turned of smart channel switching etc. nothing works.....
Is this a common issue and how do I fix it?
03-02-2024 08:11 AM
Hi Scott - did you find a solution to this? I’ve just got a Smarthub Plus and having the same trouble with Sonos devices!
