Caller display
Mags07
24 REPLIES 24
Mags07
Just moved to EE from plusnet.Having the telephone number of the person calling was very useful but it no longer shows up.How do I get it back please ?
@Mags07 : Caller ID should be ON as standard but if it isn't you need to call CS to have it activated.
Mags07
Thanks.I'm currently holding on the line,been informed it could be a long wait.But I really want  caller ID back.So I'll wait.Shame there isn't an online chat option.
Community Hero
Community Hero
@Mags07 Hopefully EE CS sort it all out for you, take it you have the device connected into the back off the EE Hub for the CLI to work? The wait may not be to long until someone picks it up. Text is not an option for EE regarding it, PHONE to 66033 is the other text option for EE to check the phone system out though. That may get EE to call you back once system test is done.
Home Phone Help | EE
Yes,it was all set up for us by open reach.I'm on the phone right now to customer service.
Mags07
Well,after some time he came back to me,said it was fixed then rang back.Came back as BT. So after he'd gone I rang from my mobile.Nothing.So that was an hour wasted.
Community Hero
Community Hero
@Mags07 Now reset your EE Hub, switch it off, give it 5 minutes then back on again, check it out after that time. When it was called back did the phone display to you BT Guide calling, if so landline operation may be working fine now, and just waiting on all the mobile side syncing up.
Will do,thank you.
Community Hero
Community Hero
@Mags07 If you wish to read see below not sure where it's at now.
Exhuasted with BT/EE support for Digital Phone CLI issues - The EE Community
