02-01-2023 06:45 PM
Why is my broadband slow
02-01-2023 07:14 PM - edited 02-01-2023 07:21 PM
Could be a lot of things.
What is your ping and latency like?
is it copper line or fibre?
when did the slowness start?
Are you testing over Ethernet or wifi?
have you tried rebooting the router?
02-01-2023 09:46 PM
20-02-2023 01:31 PM
Sorry but a bit too complicated for a couple of elderly users.
20-02-2023 01:38 PM - edited 20-02-2023 01:39 PM
@joodles : Sorry, but can't say much w/out knowing the characteristics of your line. What issues are you experiencing?
09-05-2023 01:30 PM
I did a speed check and wanted to compare with what our speed should be on our account. Couldn't find this information.
09-05-2023 01:47 PM - edited 09-05-2023 01:47 PM
@joodles : Which BB product do you have from EE?
Can't you try to do at least Point 3 of my suggestions?
