Blocked websites not working
SalemDavies02
I have tried to block websites on the app and my security settings are on moderate yet the websites are still accessible. I had tried no settings and just to block certain websites but that did not work. I then tried the default settings to block the websites and again, nothing. How do I fix this to just block the websites I want.
bobpullen
What hub are you using and what devices are you testing from? Any VPNs, Apple Relay/Private network, other similar sorts of services running on your network?
