26-09-2025 01:05 PM
We have just transferred from BT to EE and have noticed that the WiFi network name has stayed same,is that correct?
26-09-2025 01:11 PM
Part of app's linking to the router is an option to keep the SSID of your old router so as not to have to change your devices. You presumably took this option. An upshot of this is that the SSID written on the router is no longer valid but if you factory reset the router it will revert to that.
