23-09-2025 07:54 PM
I have the Smart hub, but need to boost range to the rear of my house, any recommendations for what extender to buy? Is there something specific for the smart hub?
23-09-2025 08:02 PM
@StuV Just try to get something wi-fi mode similar to your EE Router spec, not sure what that EE Smarthub is but more than likely wi-fi5! If speed is not that important you can also consider wireless wi-fi powerline devices! Linked the EE stuff below not sure if your router will be covered by them though!
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
https://ee.co.uk/help/broadband/fix-problem/fix-problems-with-smart-wifi
23-09-2025 08:27 PM
There are many variants of the EE Smart Hub. Which 1 do you have (read label or post a pix)? What is the name of the EE BB plan are you on including its speed?
26-09-2025 11:30 AM
26-09-2025 11:30 AM
Thos is the router i have
26-09-2025 11:33 AM
But which 1 of those on that page? Just say its name.
26-09-2025 02:37 PM
@StuV For what it is worth i had my Asus RP-AX58 directly connected to the EE Smarthub+, working fine but only until the messed the FW up in Feb 2025!
