Connecting smart WiFi to octopus home mini
JonP73
hello! I am trying to connect my Octopus home mini device to me smart WiFi but it won’t connect. It needs to have 2.4ghz not 5ghz, how do i check/change my smart WiFi hub?
thankyou
Try setting up Compatible WiFi on the router under Advanced > Wireless Settings & connect your device to that.
8 REPLIES 8
Maestro
Maestro
It’s the smart WiFi hub plus. I can’t find anywhere on the site or app about checking the ghz setup. Thanks!
Is that on the site or in the app?
Neither, on the router. Login to your EE Smart Hub/Router at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router.
I have done this very easily so thank you but once i input my admin password it tries to log in but nothing happens (2 green balls moving in a circle) so either it’s not working at the mo or my internet is poor
Ewan15
Expert Contributor
Expert Contributor
@JonP73  I found I had to set up compatible WIFI restricted to 2.4 GHz and WPA2-Personal.
In addition if you have had too many attempts at getting connected the Mini hub will need resetting by Octopus.
A phone call to Octopus support gets this done.
Following this my Mini Hub connected and has stayed connected ever since
Thanks Ewan, i think i’ll i just call Octopus and get them to help as you say. 🙂
