22-02-2024 02:20 PM - edited 22-02-2024 02:29 PM
My BT SH2 restarts itself every 2 weeks with a reason of SAAF. It appears to be self-initiated rather than as a result of a command from the Network Management System. These Restarts can be any time night or day. I have raised both a fault and complaint regarding this issue but am going round in circles. It is wasting Openreach Engineer’s time, as it is simply being re-assigned it to new engineers. Each time they admit that there is nothing wrong with either my SH2 or Broadband Connection and is not something they can suggest a resolution for. I have submitted the evidence I have found within my SH2 Logs and 2 others including a new SH2 that BT insisted I installed. Other people have also reported this in the BT Forum
Despite it being escalated to the BT Executive Complaints department they have drawn a blank and claimed we have reached an impasse. They are basically saying that they do not accept there is problem. They say my only course of action is to take it to the Ombudsman.
Before I consider doing that or moving to an EE Smart Hub Plus has anyone observed the same behaviour on the EE Smart Hub Plus.? My belief is that it is the same underlying hardware/system and so the 'Issue' may be happening with that Hub.
on 22-02-2024 04:28 PM
The problem is that the Hub restarts can happen anytime day or night. If they were to happen overnight or at a time of your choosing it would not be a problem. However if you are using a streaming service such as Sky Stream or Digital Voice then the service gets interrupted during the Restart. That fact that it only happens once every 2 weeks in not the issue, the fact that it happens and that BT are denying all knowledge of it is the real problem. I worked for them for 10 years and know that they are simply not willing to own up to this.
If you use a non BT designed/supplied router then at present you preclude yourself from migrating to Digital Voice.
on 22-02-2024 05:27 PM
@Gary019 not experienced the restarts when I was using a BT router during the day, mine seemed to pick a time when there was little or no traffic. Perhaps now with more active devices, or perhaps they run out of memory to hide the code or some other reason it does not happen in the way it used to.
Perhaps @bobpullen may be able to provide more of an insight regarding the reboot criteria.
on 22-02-2024 05:51 PM
The DSL is occasionally taken down overnight in-between the 2 weekly restarts, which I am assuming are to maximise the performance of the connection. The main culprit is the Entries in the Event Log that State reason SAAF. A few examples below. The suspicion is that they are restarting it to 'camouflage' an inherent Memory Leakage issue.
| 15:54:54 | 28 Oct. System restart | reason: SAAF |
| 15:39:17 | 14 Oct. System restart | reason: SAAF |
| 15:23:45 | 30 Sep. System restart | reason: SAAF |
| 15:08:08 | 16 Sep. System restart | reason: SAAF |
| 14:52:35 | 02 Sep. System restart | reason: SAAF |
| 01:26:57 | 25 Aug. System restart | reason: SAAF |
| 01:11:19 | 11 Aug. System restart | reason: SAAF |
| 13:50:58 | 03 Aug. System restart | reason: SAAF |
| 13:35:24 | 20 Jul. System restart | reason: SAAF |
| 13:19:52 | 06 Jul. System restart | reason: SAAF |
22-02-2024 07:33 PM - edited 22-02-2024 07:36 PM
@Mustrum wrote:Perhaps @bobpullen may be able to provide more of an insight regarding the reboot criteria.
The Smart Hub Plus doesn't have a reboot schedule so wouldn't be subject to the problem. This assumes that it is a remotely-initiated reboot instruction that's to blame, although I tend to agree with @Gary019 that it does look likely given the reason in the logs 🤔
22-02-2024 08:54 PM - edited 22-02-2024 09:07 PM
@Gary019 wrote:
Unfortunately the Thread 'Waiting for smart hub plus' would suggest otherwise
Where in Waiting for smart hub plus is there mention of SH (2023)? It does talk about an EE SH being sent instead of a SH+ but that is an even earlier SH which one might term as the EE SH 1.
You can see the visual diff between the EE SH+ & SH (2023) in Set up your Home Broadband EE Router
Not many users have posted about SH (2023). Think it had a short lifespan. New users of EE New BB are given SH+.
on 23-02-2024 01:48 AM
Interesting @Mustrum because over my 2 1/2 years with BT and Smart Hub 2, I had consistently more than 3 months periods, when the router never restarted, and if restarted, it was usually connected with FW upgrade, but never in such repeated 2 weeks, You mentioning.
