26-04-2024 04:45 PM - edited 26-04-2024 04:49 PM
Hi Guys
I have recently migrated over to the EE Broadband but kept all my existing BT equipment. My problem is I have 3 BT black discs and a BT Smart hub. Only 1 out of the 3 discs is working. I have tried all pairing methods but I can't get the blue light to remain steady, it just returns back to red.
I cannot get back onto the BT App to pair them as it's been switched off. I tried pairing using the network cable direct to the hub and this works until I pull the cable out and it goes red again.
Any ideas?
Thanks.
on 26-04-2024 04:51 PM
Are you asking about using the EE Smart Hub Plus or the BT SH2 on EE BB?
The black BT Complete WiFi discs do not work with the SH+. The white "high st." Whole Home discs would do.
on 26-04-2024 04:55 PM
The BT SH2 on EE BB.
on 26-04-2024 05:02 PM
In that case as the BT Complete WiFi discs were compatible with the BT SH2 when on BT BB then so should they be when on EE BB.
on 26-04-2024 05:05 PM
Ever since we switched over 2 out of 3 have been red. I don't know how else to pair them?
on 26-04-2024 08:28 PM
The best way to connect your Hub and Wi-Fi discs is to follow the instructions on the My BT app. On the home screen, select More, Your wi-fi network and then Set up new disc. This will guide you through the set-up and suggest the best location for your disc.
Alternatively, follow the steps below to connect using an ethernet cable. There's one in your Hub box.
If you're still having problems, use our online troubleshooter
on 09-05-2024 03:17 PM
Still can't get them to work. I think I'll speak to BT about getting some replacements.
on 17-10-2024 06:48 PM
I had a similar issue In that they won’t connect to the EE router. Works fine when I plug the BT SH2 back in… I’m wondering if I unpair them in the BT App (BT SH2) and then try and add to EE Hub.
I’m told the black ones work but the white ones won’t? This was by EE Tech support…
Have you tried the Factory Reset pin 📌 might help??
on 17-10-2024 06:59 PM
No, @Sparkypants , it's t'other way round. The black BT Complete WiFi discs do not work with the SH+. The white "High St." Whole Home discs do.
on 17-10-2024 07:02 PM
@Sparkypants You have the information the wrong way round, the Black works with the BT hub and NOT the EE Smarthub+, The white works with anything...
