28-10-2023 03:30 PM
Hi, I saw that BT Wifi became a EE WiFi, but I can see there is something like EE WiFi-X, what is this and how I can connect it? or maybe do you know if there is any option to do something like wifi automaticly connection? Im bored to put the password all the time, and it still kicking me out after 1 hour, or sometimes after 5 hours.
29-10-2023 06:47 PM - edited 29-10-2023 06:53 PM
I'm afraid it's all pretty complicated. Firstly it tends whether you mean BTWifi-X or EE WiFi-X. I'll start with the method for BT WiFi-named hotspots (but these are getting rarer every day) and then move on to what to do with the new EE ones.
BTWifi-X was, as you may have discovered, BT's way of letting iPhones auto-connect to BT WiFi. It provided, and still partially provides, a secure encrypted automatic way to use BT WiFi. It has been depricated, and you can now auto-connect to BT WiFi on iOS or Android with the BT Wi-Fi app without WiFi X being used, just by enabling an option in the app. But I do still use WiFi X, as its great. To use it, though, you need an out-of-date version of the BT WiFi app on your iPhone as the latest version has the option removed as BT don't want people using it anymore. The network is also being removed countrywide and is appearing less and less, so I recommend not putting too much time and energy into getting yourself a connection to it, even though its really cool. Your only chance would be if you're a BT broadband customer and already have the BT WiFi app installed and haven't updated it recently. In that case open it and go to More > Settings > Install connection profile, log in again and follow the steps. However if you can't do this you can still auto-connect anyway without WiFi X being involved if you enable the option within the app. Through a combination of the official method and WiFi X I auto-connect to almost every BT named hotspot.
This is all from the perspective of the day before EE WiFi was thrown into the mix. BT are renameing BT WiFi to EE WiFi now. First the network names have changed, then the website, and then the login page. This means that BTWi-fi is changing to EE WiFi, and BTWifi-X is changing to EE WiFi-X. I haven't found a way to connect to EE WiFi-X yet. I don't think BT/EE want it being used, at least not yet. It may be possible if you have the required technical skills to deconstruct a BTWifi-X configuration profile and fiddle around with it in an XML editor, But I think its unlikely. I haven't been able to auto connect to any of the renamed hotspots at all, and I totally understand your frustration. A short-term solution is to save your BT/EE ID password to your device and auto-fill each time. A more longer-term solution would be to try updating the BT WiFi app or downloading it if you don't have it already and trying your luck with the official auto-connect options. But note these only work on iOS and Android, not Windows or Mac. And I've never seen them work with any of the new EE WiFi hotspots.
28-10-2023 03:38 PM
Do you know what is Wifi X and if there is any chance to log in into it? or if there is any option to do something like auto log in without kicking me out after 1 hours or 5 hours. Im bored to put all these details every hour.
28-10-2023 03:52 PM
@vegerot according to the BT forum, BT WiFi-X is only available when connecting with an iPhone and is the preferred method if you have an iPhone..
28-10-2023 03:53 PM
@vegerot as per my other reply - BT WiFi-X is only available when connecting with an iPhone and is the preferred method if you have an iPhone.
30-10-2023 07:27 PM
31-10-2023 08:10 AM - edited 31-10-2023 09:01 AM
My BTWifi-X has been working right up until the name change. I think this is because I was able to use my outdated BT WiFi app to install a new profile a month or two ago with an up-to-date certificate (essentially an up-to-date set of login credentials in simple terms). As BTWifi-X has been very useful for me, I thought I'd do an experiment and see if I could connect to EE WiFi-X. To be clear this is not an official method. I managed to get a BTWifi-X config profile that worked for BT-named hotspots. I then proceeded to open it in a text editor, remove the signing (as otherwise errors occur), and find/replace BTWifi-X for EE WiFi-X. I then emailed this over to my iPhone, and installed it as normal. I was very excited nnow, as EE WiFi-X did show under managed networks. sadly the excitement didn't last long. I've tried it at 2 EE WiFi-X hotspots, and both times get "Unable to join the network EE WiFi-X". Both times I had three out of three bars. I also connected to these successfully just like week as BTWifi-X hotspots. So, sadly, the information in those linked threads is correct. I assumed it was just a name change and the old authentication mechanisms would stay untouched, but sadly I was proved wwrongand BT have actually locked this down for good now. So I recommend that you don't do what I did, as sadly its just a waste of time. If you update your BT WiFi app to the latest version it should Auto connect to EE WiFi without the need for WiFi X. Just remember this is an open network though, unlike WiFi X, so make sure to check you're browsing HTTPS websites or use a VPN if having everything encrypted is a must.
31-10-2023 10:00 AM
@Theo77 Thanks for the confirmation. Yes we do have a VPN which automatically switches on.
