21-07-2025 12:24 PM
My HP printer worked fine with my old EE router but since I have had a Smart hub fitted I can’t connect the printer to the WiFi, power cycled both , pressed the WPS button but the printer just keeps flashing with no connection , surely this shouldn’t be a problem ??
can you help ??
21-07-2025 02:25 PM
Thanks for you advice , but I managed to up date the WiFi details by logging into the printers own network !!
21-07-2025 12:53 PM
@Bally16701 You say you’ve pressed the WPS button on the printer but what about pressing it the router as well ?
21-07-2025 01:20 PM
@Bally16701 which router model do you have and which printer model?
The newer EE Routers are WiFi6 which older devices and printers cannot cope with. However there is an option for a compayible feature to be implemented which should allow the printer to connect.
If you log into the router you should find the option in Advanced WiFi options.
21-07-2025 02:23 PM
Hi @Bally16701
Can you connect via your pc and a cable/hp app.
It may just be incompatible.
Try searching the forums as this and cannon printers are posted regularly.
21-07-2025 02:25 PM
21-07-2025 02:31 PM
@Bally16701 good news thanks for letting us know.
