No broadband internet again
Aevans9
Hi, 2nd time in a few days there is no internet broadband. Have tried re setting router and again to no avail. Any ideas??
@Aevans9 : If it is a neighbourhood issue, you could consult BT Service Status to see if any faults are being attended to in your local area.
@Aevans9 : Welcome to EE's Home Broadband Forum.
