close
superfast fibre broadband
98psmith
How can the semi-detatched house I'm moving to be capable of only 3mb/s, but the house next door can achieve 61mb/s?
12 REPLIES 12
Mustrum
@pip11  is correct, although you will find sites such as SamKnows (oh no they don't) claiming that VM have LLU presence in lots of exchanges! They do not use BTW equipment or Openreach lines.
Sorry, I meant in exchange area.
mikeliuk
Hi @98psmith ,
From a practical perspective, if your choices are between 3 Mbps and 0 Mbps, you may wish to see which service provider performs best using the OpenSignal app and considering going with 4G LTE mobile broadband if your main consideration is bandwidth.
Latency and stability for gaming and video conferencing may not be as good as the average fixed line connection but I suspect may be competitive with a line that delivers only 3 Mbps as I suspect there are physical issues for why the performance does not approach a more normal number.
I currently see the below performance on 4G LTE mobile broadband and it counts as a slow day. (I've seen as high as 81 Mbps and the below result included a burst of 77 Mbps measured by OpenWRT.)
PING ms
25
DOWNLOAD Mbps
62.81
UPLOAD Mbps
29.67
https://www.speedtest.net/result/11831105945
Unrelatedly, I'm in an area where Virgin Media do not offer their services and additionally OpenReach does not offer its services. The developer's ISP Fibre Nest is the only fixed line option (FTTP) but I've chosen instead to go for 4G LTE mobile broadband to get higher bandwidths (and a greater choice of providers) for a particular price point (giving up 12 ms latency and a routable IPv4 address).
