22-06-2020 05:28 PM
Hi I have upgraded to SIM only and kept my handset and number. I have inserted the new SIM today. All calls now go to my voice mail message without ringing the phone. When I dial out on my phone it is showing a totally different number to mine.
I have missed several important calls today not good when you are dealing with safeguarding issues.
Can anyone help. I have tried calling twice and was on hold for over nearly 20 minutes each time with no answer.
22-06-2020 06:26 PM
Hi Trudy.. if it was just a transfer to Sim only then normally you would just keep using your old sim/number - that's what I did when I changed from contract to sim only. It sounds like there has been a misunderstanding and they have sent you a new sim with a new number! I would suggest giving them a ring and get it sorted out.
22-06-2020 07:20 PM
Hi @Trudypink
It's possible that you need to activate your replacement SIM which will set it up with your existing number. But my experience is the same as @wardi advises - a change from handset plan to SIM-only, is just a change of plan which doesn't need a new SIM to be issued.
If you're not sure, I would call C/S to get them to check it over.
22-06-2020 07:23 PM
Thank you I called them and after being on hold for nearly an hour, this is exactly what had happened.
23-06-2020 08:22 AM
Morning @Trudypink
Thanks for coming back and letting us know.
Is this now sorted for you?
Thanks 🙂
23-06-2020 07:02 PM
Yes thanks. It is all resolved.
