05-04-2021 05:32 PM
I'm a new member, I bought a package for 10 pounds, it shows me that I have 4 gigabytes of Internet, 100 minutes and unlimited SMS, but the mobile Internet does not work and SMS is not sent, it is the same on another phone, and when I put another SIM card everything works.
05-04-2021 06:32 PM
hello,
try opening up " gov.uk " web page or " nhs.uk " if this pages opening then EE have applied a Data cap you will find that when you call you be lest with only front line call operator who will to manage to call by leaving you on hold for long time only to back to the call to say we have run check , every thing is working fine , if you ask to be transferred to Technical yo will told i'm very sorry but they wont take calls here is the problem if your tied in to a contract you stuck if you on pay as you go the only option is add more credit .....
05-04-2021 06:45 PM - edited 05-04-2021 06:49 PM
@Innulya : Do you have credit on it or an active Pack or Add-on?
What does texting AL to 150 from it fully report verbatim (it is free)?
05-04-2021 07:34 PM
does not open
05-04-2021 07:42 PM
I have 10 pounds pack, when I try to send any text "not sent, tap to try again"
05-04-2021 08:08 PM
oh No no good
try this sender number 150
in the text box type the word " Balance "
then send
can i ask ?? do you know the brand if mobile phone you have with you ??
05-04-2021 08:27 PM
With "Balance" same "not sent, tap to try again" , Xiaomi redme 9 but I tried with another sim card from EE ( from my friend) and it's working, same when I try in his phone my sim card it's same not working mobile internet and texts, I can call only.
05-04-2021 08:49 PM
i have had a look and found some step you can try
TURN-OFF Mi Messaging on your phone. This can be done by (while in Messaging) long press menu button to enter Message Settings (Figure 1) then toggle the Mi Message to OFF (Figure 2). Downside here is you won't be able to use Mi Messaging which is pretty useful for texting friends free of charge. (that is if their connected to the internet and use MIUI too.)
[MIUI Device Team] How to solve "Your SIM card is not activated" - Mi 9/SE/T/T Pro/Lite - Mi Communi... here it the link to the rest of the steps
good luck i hope if you get fix keep me up dated with your progress my friend!!
05-04-2021 09:06 PM
[Tips] [MIUI Device Team] How to solve "Your SIM card is not activated"
