01-04-2021 09:45 AM
Can’t access internet from iPad,it shows 4G at the top along with good signal strength. Every time it tries to Monte the there is a white circle of death indicating it is searching. There is plenty of credit available. I have taken sim out and put back in, reset network settings and tried from numerous locations with no joy
01-04-2021 07:25 PM
Its a brand new ipad which work perfectly well with an iPhone sim just doesn’t work when the ee sim is used so i put the fault down to this sim
01-04-2021 09:45 PM
Yes that would seem logical. Out of interest is your iPhone sim with EE too?
01-04-2021 10:19 PM
No virgin but it works fine ee doesn’t work
02-04-2021 08:37 AM
It may be worth speaking to our Technical Support team so that they can look into this for you.
02-04-2021 08:54 AM
So I have to spend ages on the phone at probably a premium rate to resolve this issue,
to recap the SIM card doesn’t work in a brand new iPad, when I put another carriers SIM card in it works fine and I can access everything.
it seems that I will have to write the Credit I have off and find a service provider that SIM card actually , not impressed at all
02-04-2021 09:24 AM
Is the iPad locked to the other network, @Newcastleandy? You may need to have it unlocked in order to use an EE SIM in it.
02-04-2021 09:27 AM
Calls to EE C/S for PAYG issues are charged at a flat 25p per call. No-one's suggesting your credit will be lost.
Has this EE PAYG SIM ever worked in this tablet previously? If not, then a SIM-lock is a distinct possibility.
02-04-2021 11:00 AM
All sorted by technical team thanks for your help
02-04-2021 11:40 AM
02-04-2021 12:16 PM
They reactivated sim and all sorted
