| For up-to-date information and comments, search the EE Community or start a new topic. |
28-11-2021 06:23 AM
I am visiting the UK and the facilities offered bt 4GEE WI-FI MINI seemed adequate for my data requirements over the few weeks I am here.
For 9 days the system worked well then, surprisingly, a message appeared saying I had no data left on the unit. I am not a heavy user but I went and topped up the Gbytes but am still unable to connect.
After 24 hours the WI-FI MINI is still not connecting. I am unable to get an understandable response from the EE website telling me there is or is not a network problem.
To get this message on the net I have had to borrow a neighbour’s Wi-Fi.
is there something I am not doing to resurrect my service or is there a serious problem with the EE network around Tarporley near Chester?
28-11-2021 09:19 AM
@Zabrian You say BT 4GEE WI-FI MINI but what sim is in the device? Is it a BT sim or an EE sim ? BT own EE but they are two separate networks.
28-11-2021 09:49 AM
Hi Chris_B,
The “offered bt” is a typing error, it should be “offered by”.
The 4GEE WI-FI MINI comes as a kit with the associated SIM card in the box, obviously an EE card.
Thanks for the suggestion.
28-11-2021 12:00 PM
Thanks for clarifying, @Zabrian.
If you go to our add-on status page whilst connected to the 4G device, does it show that you have an allowance left?
28-11-2021 03:35 PM
Hi Chris,
When the problem started yesterday, there was a message stating I was out of data so I went to the local store and topped up £20 worth of data.
In the settings on my iPad, the Wi-Fi has a tick against the 4GEE but underneath it says “no internet connection”.
I am unable to connect the 4G unit to try your advice, I am using my iPad on a neighbour’s Wi-Fi at the moment for any messages.
Brian
28-11-2021 03:37 PM
28-11-2021 04:09 PM
Hi Chris,
I have done that and had it unplugged for an hour, nothing worked. I will take it to the EE store tomorrow, when they open, to see if they can repair it.
Brian
29-11-2021 07:47 AM
29-11-2021 05:53 PM
Hi Chris,
Went to the EE shop and to be honest I think they were also learning the procedure.
Eventually they logged onto the account associated with my WI-FI MINI and stored there was £20 credit unallocated. Listed on the page were “top up” buttons and I had to select the £20 button and the Gbytes were then credited to my account.
I used the local Co-op to buy the top up, it thus seems that this only credits the account but does not allocate the data - very strange and complicated. You have to be on line to select the data package.
in future I believe online top ups to be the solution.
I think that EE should explain the process in the documentation provided with the product, it would have saved me a lot of time over the weekend. Even the Helpdesk in South Wales could not help.
Bri@n
30-11-2021 08:18 AM
