on 01-04-2021 09:45 AM
Can’t access internet from iPad,it shows 4G at the top along with good signal strength. Every time it tries to Monte the there is a white circle of death indicating it is searching. There is plenty of credit available. I have taken sim out and put back in, reset network settings and tried from numerous locations with no joy
on 01-04-2021 10:47 AM
Hello @Newcastleandy and welcome to the community
Can you access other websites ok, or is it only this specific one that's affected?
Can you load, say, the BBC News frontpage at all?
on 01-04-2021 11:37 AM
It is all websites plus can’t access mail either
on 01-04-2021 12:48 PM
It occasionally connects to bbc sport but struggling to open ee home page and other sites. Pretty poor if im honest
01-04-2021 02:19 PM - edited 01-04-2021 02:21 PM
Do we have any problems showing for your area on the coverage and network status checker?
If you enter your postcode and select 'check network' this will show you any reported problems.
This will help us to find out if a network problem could be the cause of your data not working on your iPad.
Thanks 🙂
on 01-04-2021 03:35 PM
No the service shows as fine no problem have just checked again and its not working
on 01-04-2021 06:27 PM
It doesn’t work and extremely disappointed
on 01-04-2021 06:40 PM
NewcastleAndy.. do you perhaps have a phone sim (that picks up the internet ok) that you could try in the iPad? That would help isolate the problem. If that sim struggled too then it suggests a problem with the iPad.
on 01-04-2021 07:01 PM
Have just put my iphone sim in and got instant access to the internet Netflix and other apps put ee sim back in and no access
on 01-04-2021 07:15 PM
OK, has the ipad & sim always been like this or has it suddenly deteriorated? Either way I would phone CS and explain the situation. If it's not a reception problem faulty sims are not unknown.
