close
iPad Pro Mobile Data no IPv6 address
allisong
Hello,
I have two iPad Pro 11” devices running iPadOS v14.4.2 both on a data sim from EE and I only ever get an IPv4 address and never an IPv6 address from EE when on Mobile Data. (It is fine on my home WiFi). My iPhone has both IPv4 and IPv6 all the time. Tried putting the iPad SIM in my iPhone and it gets both IPv4 and IPv6 addresses so it is not the SIM. It seems that EE sees the device as an iPad and only gives it an IPv6 address. Very strange!
Tried contacting EE support and they had no clue what I was talking about!
Anyone able to help!??
10 REPLIES 10
Leanne_T
Hi @allisong
Have you had an iPv6 address showing previously?
If you put your iPhone SIM card in the iPad does this get both addresses?
Thanks 🙂
Yes I get IPv6 if I use an Pay as You Go sim from another network. If I swap SIMS with my iPhone then the iPhone gets IPv6 fine still but the iPad still does not. iPad is definitely able to use IPv6 fine but the EE carrier settings or something seems to block it....
Christopher_G
Is there a carrier settings update, @allisong?
It should pop up when you tap Settings > General > About, if there's one available.
Also, is it on the latest software version?
No carrier updates it is on v45 from EE same as iPhone, software version is first post and is absolutely latest but issue has been with me through various versions as this has been the case for six months or more.
Christopher_G
OK thanks, @allisong
Could you try resetting the network settings please?
Tap Settings > General > Reset > Reset Network Settings > Follow on-screen prompts.
Already tried lots of times, no joy!
Christopher_G
Have you tried a full backup and restore, @allisong?
How to back up an iPad >
How to restore an iPad to default settings >
Yes, issue was on my iPad Air 2 recently backed up and restored to my new iPad Pro 11” plus our other iPad Pro 11” (new) on the same service has the same issue (only on EE).
Christopher_G
Are you having problems with a particular service that needs IPv6, @allisong?
X
LinkedIn
Facebook
YouTube
