05-07-2021 08:04 PM
what are the dns server settings for my Huawei 4GEE Home Router 2
06-07-2021 08:23 AM
Hi @michaelwatts.
Welcome to the community.
If you log into the router's home page using the login information on the side of the router, you'll be able to access your router's settings and see what they are.
Jon
08-07-2021 04:33 PM
08-07-2021 05:27 PM - edited 08-07-2021 05:28 PM
Hi @michaelwatts ,
If your NAS wants different DNS, it may make more sense to set it directly in the NAS to avoid reboots needed to pick up from the the router/DHCP.
The router manual should be available online and I think it would be unlikely for the service provider to disable that functionality.
From the NAS, are you able to ping first the gateway and then the desired DNS?
26-09-2021 04:56 PM
Which page are they on - have looked but the settings do not appear to be present? I suspect they have been disabled in the firmware used by EE for this router?
