close
change sim plan but my 20% discount code is not valid
rose_thyme
I would like to change my sim plan but my 20% discount code is not valid when I select the plan I want.
@rose_thyme  does the plan you’re choosing already have a discount on it ?  If it does you can not apply a 2nd discount to it.
Christopher_G
Hi @rose_thyme
Which plan are you trying to choose? If you select a different plan, does it work?
If you're connected to a VPN, could you try without it activated?
