01-08-2020 02:50 PM
Recently took out mobile broadband fir a caravan after being advised coverage would be good
Getting 0.5meg download speed,
Could ee supply an antenna to boost this or should I look to cancel?
01-08-2020 03:46 PM
I'm guessing you've not tried an EE phone in the same location to compare coverage & speeds..
What does the coverage checker say for the location?
01-08-2020 05:34 PM
Thanks for the response, Have an ipad on EE and that's absolutely fine.
02-08-2020 08:21 AM
Hi @Jam3s.
Are you aware if anyone using an EE mobile is experiencing problems within this area?
As the coverage checker shows OK speeds, I would recommend giving us a call so our technical care team can look into this further.
Katie 🙂
02-08-2020 03:31 PM
Hi.
Yes a friend has the same issue and brought an antenna this weekend and is now getting 30mgbs download... but his contract was old whereas I've only just took mine out.
03-08-2020 08:45 AM
Hi @Jam3s.
Our Tech Gurus will be able to look into this in more depth with you.
I'd recommend getting in touch with them so they can run through troubleshooting.
Jon
