close
Z Fold 3 eSim
Jalan3103
Hi All,
Does anyone know if the Galaxy Z Fold 3 supports eSim?
Will be transferring from iPhone 12 Pro Max with an eSim.
Just want to double check as if it doesn't I'll have to visit a store to get a physical sim.
Thanks,
@Jalan3103  Yes it has an eSim.   I highly recommend not using an eSIM unless you really need to have two Sims in your device because just swapping the Sim card over is much easier than going through the rigmarole that the eSims can cause.
I would just get a replacement sim now at least it’ll work straight the way.   the eSim activation from your account is not there at present so you need to request a QR code and have a working sim to change over to the eSim anyway.
