For up-to-date information and comments, search the EE Community or start a new topic.  |
19-07-2021 11:54 AM
Hi. I'm on EE fibre. This is been goin on for a while, WiFi speeds keep dropping from about 15mbps to almost 0.5 and I have to keep rebooting the router.
I've spoke to EE customer service before but nothing seems to help, just rebooting... Tried all tricks such as separating the channels and renaming them.
Should I get a new router/modem? The new white smart WiFi?
The problems is checking with EE app it says my line speed is 15mbps even when WiFi is down, but our pc that is on Ethernet slows speed down too?!
Working from home so this is a real issue for us. Please help!
19-07-2021 02:13 PM
Hi @Jannen
I hope you're well and having a nice day, other than this issue of course.
I use my home broadband for everything so totally get the importance of a fast and reliable connection.
We have a great How Can I Fix My Home Broadband Connection guide that's full of tips that may help with this.
However I know you said you've already tried a lot, so the next step may be to have our experts take a look. If you have an EE mobile you can text HELP followed by your landline number to 60071 to get the ball rolling.
19-07-2021 02:53 PM - edited 19-07-2021 02:53 PM
2. Try both a wired & a wireless speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
