close
Wifi calling not working, iphone 12
ClareDevon
Can't get wifi calling to work on iphone 12.
I have switched the wifi calling button on, have reset wifi, turned it all off and on again.... I have no bars of signal at home so rely on the phone for work and other calls. Any tips would be great! Thanks
8 REPLIES 8
Northerner
Hi @ClareDevon
Are you PAYG or pay monthly contract? (Although both now work on WiFi calling)
Are you definitely connected to WiFi, can you access the internet?
Are you in the UK?
Jon_K
Former EE Employee
Hi @ClareDevon.
Has WiFi Calling worked on this phone before, or is this the first time you're trying to use it?
Jon
Hi @Northerner I am on a monthly contract.
100% connected to the internet, the symbol is there and I can access internet and apps no problem.
Yep in the UK, deepest Devon!
Many thanks
Hi @Jon_K , this is a pretty new phone - got it in July and over the school summer holidays never got round to sorting this problem out!
Jon_K
Former EE Employee
Thanks @ClareDevon.
Can you try resetting the network settings on your phone?
You can do this in Settings, General, Reset, then Reset Network Settings.
You'll then need to reconnect to WiFi can activate WiFi Calling again.
Jon
Thanks. @Jon_K - I did this last night after some googling, but it made no difference!
Jon_K
Former EE Employee
Thanks @ClareDevon.
I'd recommend getting in touch with our Customer Care team about this.
They will be able to check your account and run through additional troubleshooting with you to get this working.
Let us know how you get on.
Jon
I have the same issue. New SIM with a New iPhone 12 mini and the wiFi calling is the only thing that doesn't work.
I seem to remember the same thing happened to my phone when I moved to EE. This was fixed instantly by an EE rep on the phone. But it seems impossible to actually speak to a real person by dialing 150 at the moment. EE you need to employ more staff!!!!
You mention getting in touch with Customer Services but how can you when they don't pick up the phone!!!
