close
Wifi/broadband connection
CR29
I would like to know why my broadband connection got so weak over the few months now.  It is getting worst both day and night. This is a constant issue since I have joined EE.
EE can you please sort this out otherwise, I will do what I have to do.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
