What’s the difference
Lauren82
Hey! I’m so confused about the sim packs! What’s the difference between pay monthly ads pay as you go?
I pay £25 monthly and get 20gb, but I could go pay as you go and get 8g for £10, which would be Korey jan enough as I use my WiFi at home! But looking at them, what IS the difference between the two types of plan???
@Lauren82  Pay money is a contract and you agree to pay the tariff price until the minimum term.  A contract will allow you to call/text via WiFi calling you don’t get this with PAYG.   You can also make 4G calls and use data at the same time.  With PAYG only your data is via 4G all calls are via 3G and you can not use data at the same time.   So if your using your device as a Sat nav and someone calls you your sat nav will stop.    With PAYG you can have data roll over and you get boosts every 3 month so you could increase your call/text/data allowance every 3 month.    With PAYG your not committed to stay with EE for a set length of time and you can leave when ever you want.
Aaaaahhhhh thank you! That makes sense now!!!!! Might just stay with my pay monthly then!!!!!!!
