close
Use of data abroad
Maria011
Hello!
I came in Greece for the summer and I can't use my data at all. How can I fix that?
I can't even turn them on.
7 REPLIES 7
@Maria011  Are you on contract or PAYG ?
   If your on contract you can only use your tariff allowance for up to 2 months while out of the UK after this time you might be charged for international calls/text and you might need to purchase any data you want.
I am on a contract but I didn't have issues like that before. I was in Greece last year for  7 months, returned to England (couldn't use my data in England because I had used everything and I was waiting for the next bill) and when I returned to Greece a few days ago the signal is one or two bars and I can't access my data at all.
@Maria011   So you have a signal on the device.  It might be a device settings that needs to be enabled or it could even a network issue there.
Any ideas what can I do about it?
I think it's the signal because when I try to access my EE data it doesn't work at all. But if I try to access the data from my greek number it works.
It's just weird because it's the first time it's happening. Usually in Greece my EE data were working better than the greek ones.
James_B
EE Community Manager
Hi @Maria011,
Are you able to make calls and send texts?
Yes I can
Hi @Maria011
Could you please follow the below instructions for me.
Log into your MYEE Account via our website (not the My EE app)
Once logged in select 'Menu' then 'Manage Your Device' and then 'Usage Controls'
'Roaming Abroad' and ‘Call Abroad and Premium Rate’ both need to be turned on. If they are turned off, please turn them on.
Once this has been done please let me know if it works.
