26-09-2021 08:11 PM
Evening, I have a EE 4g MIFI (dongle) that won't connect to AnyDesk/TeamViewer. I can use a hotspot to connect but not using the 'dongle'. Any thoughts/ideas?
27-09-2021 08:18 AM
Hi @Wally375
Thanks for coming here.
Do you get an error message when you try and connect?
Are you using a VPN?
Thanks 🙂
27-09-2021 05:45 PM
Hi Leanne,
AnyDesk is not connected to the server. Please check your internet connection.
As I’m typing whilst connected to the internet you can tell there’s something not happening. Only bought the thing to work from home using AnyDesk.
Rgds
Wally375
27-09-2021 05:46 PM
Hi Leanne,
I can use my GiffGaff hotspot 100%
Rgds
Wally375
27-09-2021 05:46 PM
No VPN involved.
27-09-2021 06:46 PM
Hi @Wally375
Can you access the internet whilst connected to the WiFi on other devices?
Thanks 🙂
27-09-2021 06:53 PM
Hi @Wally375 ,
There's a good chance it's worth checking if your router is set to IPv6 dual stack (IPV4V6), and the fix may be to set IPv4-only if it is.
A search on this forum should provide guidance on either editing or adding an APN to accomplish this.
