05-03-2021 07:10 AM
Hi
Can anyone advise on my issue .
Ive had my S10+ for over a year and it wont find any updates
Currently stuck on Android 9 and Security patch 1 from 2019
It simply says when you try " your software is up to date"
Any help or advice much appreciated
05-03-2021 07:53 AM
@Jaijai Where did you get this device from ?
05-03-2021 08:14 AM
It came from Fonehouse.co.uk with an EE contract and sim
05-03-2021 09:05 AM
Hi @Jaijai,
I'd recommend reaching out to Samsung support. They'll be able to check if there are any updates available for your device.
05-03-2021 12:29 PM
@Jaijai it’s not a EE supply device updates for that device don’t come from EE they come direct from the manufacturer .
05-03-2021 07:43 PM
Done exactly tgat and it turned into a nightmare .just so others know if they have the same
Samsung advised using smart things app on PC and could offer no reason why it wouldn't get updated .It hadn't updated since new .
After downloading smart things i hooked up and sure enough it said you need to update
4 hrs later it says all done but there's another update ,it had went fro Android 9 to 10 and UI 1.0 to 2.5 .
So i go again 3 hrs later my phone bricks and goes into a never ending restart loop and a warning screen with 3 options
Try again
Erase all app data
Visit a store, try again just looped the restart so it was erase all app data to get it to
Eventually fire up using safe mode where i had to factory reset and re install again .
Sorry about the long winded answer but i hope it might help others .
Many thanks for all the replies ,its been a looonng day
06-03-2021 10:53 PM
Hi @Jaijai
Boot into safe mode and clear the cache, then restart and go to software updates.
It should work now.
