For up-to-date information and comments, search the EE Community or start a new topic.  |
21-12-2021 07:40 AM
Updated my Google Pixel phone and now it's stuck in Fastboot Mode and won't do anything else.
21-12-2021 09:02 AM
Hi @Lizzie121 ,
Do you know if the software update process completed to the end, or might it have been interrupted by something such as running out of battery?
21-12-2021 12:03 PM
yes, the update completed. ive tried the simple on / off and reset options but it doesnt budge from Fastboot mode...
21-12-2021 12:15 PM
Hi @Lizzie121 ,
Online indications are that you should try Safe Mode https://thedroidguy.com/how-to-fix-google-pixel-3-xl-stuck-in-fastboot-mode-1095797
Another good play would be to do a search to obtain online technical support such as from https://support.google.com/pixelphone/gethelp
