close
Sims...
Bazzzra
Is there a card for data that you can pay for a set amount and not have to renew it every thirty days.  Like you only top it up when you are running low?
Regards,
Barry.
Yes, it's called PAYG but you have to stop the recurring pack that all EE PAYG SIMs come primed with.
Text STOP PACK to 150 before you next top-up & you can use the SIM for calls & texts but not data as normal PAYG at standard per-unit rates paid for out of your standing PAYG credit balance.
To save the SIM going into hibernation due to lack of use, just remember within every 179 days (~ 6 months) to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from any Pack or Add-on you might have.
@Bazzzra  You can purchase a data only sim where you get a set allowance over a set period of time.   In this time you can use a certain amount of that data allowance depending on that length of time. See HERE
