close
Security
Lynday
Hi I’ve jus bought the rest mini WiFi box but it keeps saying weak security, how do I make it stronger?
It won’t let me click on router to change code as previously read that’s wot to do?
any advice plz ?
Lynday
Hi I’ve jus bought the EE mini WiFi box but it keeps saying weak security, how do I make it stronger?
any advice plz ?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to change the WiFi to:
Security = WPA2 PSK
if it's not already, as it should be.
