close
Samsung Galaxy Smartwatch 46mm
Dariusz80
I cannot connect my 46mm Samsung Galaxy Smartwatch to the plan in EE.
I do not know why?
20 REPLIES 20
James_B
EE Community Manager
Hi @Dariusz80,
Which phone are you using?
Samsung Galaxy Note 10+ 5G
James_B
Did you purchase your watch from EE or another retailer, @Dariusz80?
In Argos.
James_B
Hi @Dariusz80,
To purchase a data plan for your watch:
1  -  open the Galaxy Wearable app
2  -  select Mobile Networks and then Next
3  -  log in using your EE account details
4  -  select the EE Smart Watch plan and agree to the Terms
5  -  follow the instructions on your phone to complete the set up
6  -  your phone will notify you when your mobile connection is set up (it can take up to 4 hours)
Hope this helps.
Yes i do. 1 and 2 are ok. And that's it. There is information that it is impossible to configure the tariff plan and I have to check if the phone is connected to the network. And I still don't know why this is so.
Screenshot_20201127-122219_Galaxy Watch PlugIn.jpgScreenshot_20201127-122219_Galaxy Watch PlugIn.jpg
James_B
Hi @Dariusz80,
It looks like you only have a weak mobile signal at the moment. Are you able to try the setup somewhere with a stronger signal?
My signal is very good. The internet works very well. I have maximum signal. I live in central London. I checked in many places. In the building and outside.
