close
Renewed contract - rubbish connection
Andymac2602
I have just recently renewed by broadband contract. It was OK, but not perfect, before. Since then it has become worse and even non existent regularly. Considering breaking my contract for non provision of service, a breach on the part of EE. It seems that EE are not even interested.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
mikeliuk
Hi @Andymac2602 ,
"Breaking" your contract is likely to be a very bad idea as it's likely the contract will be enforceable against you and you would be compelled to pay a cost equivalent to if you continued the contract for whatever minimum term agreement that you committed to.
You would need the service provider to release you from your contract for a valid reason such as if they do not believe they can provide the service which you are paying for.
You may wish to check your renewal terms to see if you have any cooling off period in which to cancel your decision to agree to a new minimum term period with the service provider. Good luck!
@mikeliuk : There is a 14-day cooling-off period from the upgrade going live if it was ordered online or by phone.
Beyond that EE won't release you from your contract .w/out 1st having the opportunity to investigate the issue & coming to the conclusion that it is unable to fulfil the contracted service.
What do you mean by "renew"? There's no such thing as renewing these contracts. You either:
  • Upgrade to a new contract even on the same BB package, or
  • Stay on the existing contract with the the same BB package, on a ongoing rolling month's notice.
