Registering EE sim card first time
3fab
Why I still cannot make/receive calls after registering the sim card with an operator over the phone having a pay as you go have just topped it up? what else need to be done?
If you're in the UK, then putting credit on the phone will indeed allow you to use it.
All new PAYG SIMs need to be used in the UK, so you will either need to send that SIM back to the UK, or call C/S to arrange a lost/stolen replacement to be sent to your UK address. Then make sure that SIM is used in the UK before beng sent back to you.
Hi @3fab
What happens when you try to make a call? Or when someone calls you?
If you text BALANCE to 150, what does it report?
I am in Spain at the moment:
If I make a call to UK number : Voicemail saying "Call to this number are barred"
If I make a call to ESP : Voicemail saying "Call to this number are barred"
If I trie to reach this new ee number voicemail saying "The person you have called is not available"
If I try to sena txt to 150 .. Not delivered
But I just topped up 5 euro and plus I can see it in my EE Web account
Super confused..
Has this PAYG SIM been used in the UK previously?
If yes - does your phone show signal bars?
If no - that is your problem. All new PAYG SIMs need to be used in the UK first, before they will work abroad.
Really? the operator told me over the phone that as first timer after the to top up it would have automatically activated the card!
Seriously there is not other ways and I am without phone till I get back to UK?
nightmare
